It may be a fuse device /thermal cutout rather than what looks like a small disc capacitor if you bypass the device just for test purposes you will be able to see if this is the problem or a fault further on thats if the transformer is still ok you should get a reading across both coils using a meter on resistance reading.
Hi, I've bypassed the small blue disc with a fuse and yes the unit now works although it doesn't seem to want to switch off. I'm tempted now to wire a switch (lamp on/off type) into the mains lead, however if I can find out the value of the capacitor or whatever I should be well placed to renew it which would be the proper way I know.
Whats the model number of this unit?
A Schematic is usually available for most Sony gear.
Hi it's a HCD-EP303. I thought the schematic would be mega-bucks. Do you know where I can obtain one. Thanks again for all the interest guys.
