The dno saying they won't touch it because of the tenby clip so it's no longer their responsibility
How do they know about the Tenby clip ?
We can but guess what the situation is. However, as I wrote, maybe they regard the fact that it has such a clamp (which, as you say, they presumably can only have ascertained from a photo) to indicate that they did not provide a TN-S earth (i.e. regard the installation as TT) but that 'someone else' has tried to- in which case they would, of course,have no obligation in relation to, or responsibility, for maintaining the earth.To clarify, the dno don't like the fact that a regular gas/water bonding clamp has been used, and presumably they want to see the 'proper' earth clamp that is supposed to be used.
Usually the DNO should have records of which area has which earthing arrangement.We can but guess what the situation is. However, as I wrote, maybe they regard the fact that it has such a clamp (which, as you say, they presumably can only have ascertained from a photo) to indicate that they did not provide a TN-S earth
I'm certain a BS951 earthing clamp is deemed unacceptable for providing the earth from a supply cable - even though 'everyone' does it.We can but guess what the situation is. However, as I wrote, maybe they regard the fact that it has such a clamp (which, as you say, they presumably can only have ascertained from a photo) to indicate that they did not provide a TN-S earth (i.e. regard the installation as TT) but that 'someone else' has tried to- in which case they would, of course,have no obligation in relation to, or responsibility, for maintaining the earth.
They should,but often don't seem to be sure when asked. However, as I wrote, they may be assuming that since the 'apparent TN-S' uses a clamp which they don't use, then it is is not an earth which they provided, hence not an earth which they have to maintain.Usually the DNO should have records of which area has which earthing arrangement.
... and the converse. See above in relation to the situation in which they believe that they have NOT provided an earth.If the DNO has provided an earth. They must maintain it.
Quite so - 'everyone' other than themselves.I'm certain a BS951 earthing clamp is deemed unacceptable for providing the earth from a supply cable - even though 'everyone' does it.
... and I've just written, maybe it is an indicator to them that they didn't provide the earth, and therefore do not have to maintain it.I imagine it's one of those situations where the company won't touch it if it doesn't meet their criteria, even if electrically it makes no difference.
Whats the bet on it being a TT installation then?... and the converse. See above in relation to the situation in which they believe that they have NOT provided an earth.
Right.Quite so - 'everyone' other than themselves.
A lot of people are wrong.A lot of people say it's a C2 and a call to the DNO
and as it's looped, 50/50 that they have attached it to the wrong one, i.e. the cable that goes next door instead of the incoming supply.The Tenby clip looks to have been installed by someone and has been put on the armours of the cable hence the high reading.
Indeed - so, given the absence of any up-front S-typoe RCD, whoever installed the CU (and maybe also even the clip/clamp on the incoming cable) presumably was considering it to be TN-S? However .....It is very very unlikely that one will acheive a stable Ra anywhere near good enough to allow enough fault current to flow, in order to trip any MCB. ..... Bear in mind that the only decent way to acheive discrimination with RCD's is to use S types. RCBO's are a good way to go too.
... the 'bet' presumably needs to be on what sort of installation the DNO regard it as being, doesn't it?Whats the bet on it being a TT installation then? .... By looking at the install I doubt it was a TT.
Does that not imply that the DNO didn't do it (and therefore may not have "provided an earth")?The Tenby clip looks to have been installed by someone and has been put on the armours of the cable hence the high reading.
