can Hive control underfloor heating?
the supplier says it wont.
I thought it was just controlled the thermostat / timer?
the kit comprises:
brass mixing manifolds 1 x 7 port (mixer valve, thermostatic head, pump, temp gauge, pressure gauge, flowmeters, auto air vents)
thermal actuator
22mm zone valve
danfoss FH-WC wiring centre
danfoss wt-p thermostat
16mm AL/pert pipe
(info: Im sorting for a client, plumber will be fitting but he is away at mo so cant get hold of him).
TIA
the kit comprises:
thermal actuator
22mm zone valve
16mm AL/pert pipe
TIA
