Impossible.She reckons on all day to heat it to temperature with the cover on.
I think that calculation may be a little pessimistic. IHNI either about the likely heat losses from the tub, but what I do know is that a 'fixed figure' (be it 300W or whatever) is not really appropriate during the heating-up phase. Particularly with a cover, there will presumably be no significant heat loss until the water temperature rises above the ambient temperature (which could be well into the 20s (°C) in a reasonable summer), and even once the water temp is above ambient, the heat loss will be roughly proportional to the water-ambient difference, hence pretty low until the water gets quite warm.IHNI what the losses are from your s-i-l's tub are, but if we use Porque's figure of 300W, that makes the net input of the heater 1.7kW, i.e. 6.12MJ/hr.
Which will raise the temperature of 2850l of water by 6120000/(4.19 x 2850000)°C per hour. = 0.51°C per hour.
I believe that a mains water temperature of 10°C is commonly assumed, but lets say that in the summer it gets up to around 15°C? To take it to 40°C would take just over 2 days - is that what she finds?
True (well, about 1¾ days). Of course, as you (I think) have observed, what we don't know is what final temp ricicle's s-i-l regards as 'fine' - by your calcs, it could get up to about 30°C in about 'a day'.With no losses at any time it's 0.6°/hr, so just under 2 days....
Potentially true, but that's a manageable issue.Hot tubs: a breeding ground for some very nasty bacteria.
A friend of mine in Wiltshire has one. I had not seen him for 2 years and i turned up for a weekend birthday party on the friday. There was no rcd protection has he had a bs3036 fuses and the tub did not contain its on rcd protection. I would not get in on the friday night and was accused of being a scare mongerer. I just sat and drank wine observing the potential dead. On the saturday morning, i went to a local retailer and bought an rcd plug in outlet so that i might feel a little more involved on the saturday night. When energised the rcd was disconnecting immediatley. no test equipment so tested by plugging in other devices, no problem. I discussed the potential dangers and told them in no uncertain terms that it should not be used under any circumstances. beers and beers later, they removed the rcd and were partying in there. I again sat nearby, drank wine and watched the potential dead. Amazing.
... and, indeed, how much better we may have survived with them! [/more sarcasm]It makes you wonder how we ever survived without RCDs...[/sarcasm]
