THIS QUERY DOES RELATE TO ELECTRICS AND NOT PLUMBING SIDE OF THINGS.
Here is brief rundown of my situation.
My problem is that the central heating circulating pump in the airing cupboard is connected directly to a switched-live connection and as soon as the switched-live connection (triggered by the room and/or hot water cylinder thermostats) is broken the pump goes off straight away.
what I need is for the pump to still run for 60 seconds after the switched live connection has been broken hence the need for a 60 second off-delay 240 volt relay switch.
Is there such a switch/relay out there available to fit??
Thanks so much.
Steve.
Thanks so much.
Steve.
