Hello Everyone,
I have a tendency to waffle so please bare with me!!
I have recently moved house (flat), I detected a small puddle water in the loft which I assumed was a small leak in the roof, closer inspection revealed that the expansion tank was heating up and steam was condensing on the roof and running down the inside.
I have observed the tank while the heating is on and a constant trickle of hot water returns are taken to the header tank all the time the heating is on, the speed seems to reduce as the heating heats up (which I presume is due to the water initially expanding as it heats up?). The water level in the tank never changes much, it doesn't go anywhere near the overflow and doesn't trigger the ball cock.
All the radiatiors heat up properly, very hot as the boiler was set to max, I have since turned it down a bit but it doesn't seem to have made much difference, the boiler incidentally is quite new, the seller informed me he replaced it in 2011. The expansion tank is probably about 15ft above the boiler, possibly more, the tank is right at the peak of the loft (large loft) and the boiler is in a cupboard halfway up the stairs between the ground and first floor (its a first floor flat with private stairs).
The other thing is that, the hot water cylinder is also in the attic, it is on the same system as the heating, i.e. you cant have heating or hot water, only both or neither, which I thought was a little strange?
In time I will probably look to get a combi boiler as I can't stand hot water tanks and the cold showers / large gas bills that they bring! I know every system is different (I'll try and get a picture) but does anyone know how easy / difficult it would be to put the heating and water on seperate systems in the mean time, I believe you can install zone valves to split areas of pipe work up?
My thinking on the hot water in the header tank is that if the boiler is pumping water up to the hot water cylinder in the loft then it only has another 6ft or so to overcome to pump it into the header tank?
Any opinions / advice gladly received
