Where is the supply from the cylinder? Is that coming out of the top of the cylinder? There should also be a vent that should run from there up and over the CWSC.
Given that it's gravity fed primaries then having them venting themselves up to the CWSC isn't really that much of an issue, not a normal approach to join them though (are the returns joined too?). They may be joined as a bypass - is the aga solid fuel or gas? - the concern would be though that they could be shortcutting themselves with both trying to feed both coils.
Yes the top of the cylinder is normal. There is an immersion and there is pipework as you describe - the hot water exits the cylinder at the top and there is a vent there too (leading to the big loft tank). There are no issues with the flow of the hot water out of the taps. Once the HW is heated everything is fine. It's just that it takes forever to heat up so the boiler constantly has to turn itself off waiting for gravity to do it's thing. The aga and boiler are oil.
As many posters have said, a 22mm gravity system is a bad idea. Every engineer that's looked at it says it's crap and needs ripping out so I think everyone is in agreement . Until it can be replaced, are there any other DIY solutions? If I fit a small 100W pump to the HW circuit will that help? Will it cause any problems? Will it send water shooting up the vent into the loft tank?
