Sorry for the dallying in replying; no I used another timer not bought one, dismantled original and cleaned and reassembled, but the same result. Will try to borrow/obtain another motor to test that, though it worked in a way, but not totally convinced.
I thought the testing on the motor was conclusive and eliminated from diagnosing the fault. If it worked everytime alternating between the 2 lives (10-20 times should do it) then the motor should be fine.
