K
Klaus_K
Hi, I have two power showers which are fed from my header tank - all done in the correct way as far as I can see - each with their own direct feed. The only issue is that when the showers are running then the header tank has to fill up, naturally enough, to make good the water being fed to the shower(s). Unfortunately, this is really noisy - just gushing water, but a lot of it. My toilet cistern has a tube made out of polythene sheeting which acts as a noise reducer, since it effective directs the water beneath the surface, so you don't get the noise of splashing - I was just wondering if something similar is available for the main header tank. Obviously, I don't want to risk siphoning, but something similar to the cistern ought to work, surely? I could bodge my own solution, but it'd be neater if I could buy a proper product (if one exists).
