- Joined
- 24 Nov 2004
- Messages
- 431
- Reaction score
- 5
- Country
A solar PV salesman came round the other day, and gave his pitch on a rooftop grid tie system. I am amazed that consumers are "going for it" at 59 degrees North Latitude in temperate (read cloudy) climate, but apparently they are. (!)
The salesman explained that an advantage of a small generator (ie <=4kW) is that it (the grid tie inverter output) could be fed into a spare way in my CU, allowing me to get "first dibs" on the energy collected from the PV panels. spare energy from the panels is exported, via an export meter.
forgetting all the IEE regulations/FIT/supply/demand politico-economics for the purposes of this argument,
why does it matter where the grid tie inverter is connected? if it is connected to the 100A cutout position, I think I will still use my solar energy first, due to Kirchoff's law(?). As I understand it, the Grid Tie Inverter keeps its volts out just higher than line volts in order to get its current to flow out of it? (how it does this I have no idea)
Again due to kirchoffs law, if (due to the high loading/low resistance in the final circuits in my house), this high Inverter output voltage will cause the current to flow "preferentially" around my final circuits. the current will tend to resist the higher apparent impedance on the outside of the house, because there is high volts already on that side (due to power stations).
If I disconnect all my finals, the house will be high (almost infinite) impedance, and then my inverter volts will push current to (I presume) the nearest neighbour's load?
I could tie my inverter output into a point on the underground 240VAC cable in the back garden which is equi-ohmic between me and the neighbour, then we both get an equal take of the inverter output?
taking the same argument to wind power, there has been a high uptake of FIT windpower, with 6kw eoltec machines. farmers put them up in a field, and they go through a grid tie inverter onto the 240VAC line. the owners only export electricity in this scheme (they do not believe that they get "first dibs" on the wind energy collected in the field). However, I contend that if the inverter is situated very close to the high electrical demand presented by a modern farm, then they WILL be using their wind energy first.
I know this is a bit esoteric.
but am I wrong in any of it? please could greater minds than my own explain where I am wrong?. Thanks in advance.
