- Joined
- 24 Nov 2004
- Messages
- 432
- Reaction score
- 5
- Country
one does not care (within reason) what the voltages and currents in the line are[/b]
hmmm, yeah, there may be something in that comment indeed.
Plugwash,
the main thing* that the inverter actually needs to be monitor is the input voltage. If the input voltage is too low then the inverter is overloading the source so it should reduce the output voltage. if the input voltage is too high then the inverter is underloading the source so it should increase the output voltage.
yes, this makes a lot of sense. I believe the inverters have to be "tuned" to whatever device they are acting for, in order to do just this. (clearly the windmills or PV's are not linear in operation) Power Point Tracking or something I think, from SMA.
So, from your explanations, I confidently conclude that an export-only windmill, connected in very close proximity to its owner's domestic CU, will in fact be preferentially supplying it's owners' electrical demand.
extending this argument further to my previous rant about export cable capacity;
all the windmills in orkney will preferentially supply Orkney's demand. only when this is done are export amps available.
And, as OFGEM /Scottish & Southern Electric are whinging about their grid's capacity to carry energy south, we can assume that the southbound link is "tight". so there will have to be even more amps available in Orkney's generation pool to overcome the transmission losses southbound.
Please could someone shed more enlightened light on this than is available in my weak brain?
