honestly..... if you have never done any roofing before I think re-roofing your home would be quite a task no matter how good you are at picking things up.
1st of all you WILL need help. There will be a lot of waste for a start, as it's a rosemary tiled roof they will be gauges at every 100mm (give or take), so a lot of battens to remove which takes time.
Once the roof is stripped (just take on 1 side at a time), you need to de-nail and clear all the waste. I always make sure I have some big tarpaulins to hand just in case a downpour turns up which is quite regular in the UK as we all know too well and the tarps can get your roof back water tight(ish) in no time.
When starting the new roof get everything you need to hand on the scaffold, roll your first length of the felt half into the gutter, or if using felt support trays (eave protectors) just leave you're felt sitting above. Felt from right to left, nailing in the top right corner and rolling half way. Pull tight, straighten it up and then double nail top and bottom and then repeat. (If it's windy don't go as far) But I'm guessing you'll probably know this as your thinking of DIY'ing your roof but remember your first gauge is dependent on the tile or slate you are going to use. Just remember to have at least 50mm overhang at the front of the fascia board into the gutter.
Then work out your even equal gauge from your first batten. Once you have your gauge you can hit one miss one to get it water tight quicker, then fill them in on the way back down. Once the felt is on your water tight
and inside your house shouldn't get any more than a few drops, and you can tile/slate at your leisure.
Just keep an eye on the weather forecast, leave as much of the original lead at the abutments which helps keep water tight, work speedy, get another 2 pairs of hands on the job and you should have your old roof off and water tight within a day.
Good luck,
