No more nails was mentioned earlier. This does take 24 hours to go off. I have used 5 min Araldite as it sets the Rawplug solid whilst one makes a cuppa.
I was doing a bunch of them, so once I had the gun out it was quick and easy, and very cheap, and was hard by morining. I got good results using the cheapo rubbishy version from the Pound Shop.
I'd agree - I'm in a similar age house - I find that whenever I've been lazy and use the hammer drill I end up with a hole that's too large due to having to lean in to the drill too much etc. - when I use the SDS I never have that problem - and I'm using decent drill bits with both.
Mind you when we're talking SDS then it could be a cheapy job from screwfix/b&Q for this - I don't hink we're suggesting investing in a bosch blue etc.
Very technical guys! Eeeek! Could someone tell me what an SDS drill is and how it differs from just an ordinary one like mine please? Mine's just a cheapie from B & Q, which replaced the Black and Decker my Hubby burnt out trying to drill a hole in the wall whilst the thing was in reverse! lol (He's now sticking to the things he's really good at .... like everything EXCEPT diy.)
By the way ... update ... I've put up a shelf and it's still up! I even used a level (horizontally to get the shelf straight and vertically on the brackets to get them straight too) I just amazing myself! Keep the tips coming please, they're giving the confidence I never had before. Many thanks to all who have replied.
My house was built about 1900. Stone to the front, very hard non-porous bricks to the back with a mixture of newish and very old plaster inside. Everywhere is very hard to drill and I have to use the hammerdrill always. I have to really lean into the wall with the drill and this often means that the holes end up bigger than I need. So .... I've decided to always use a smaller drill bit than I need.
