I am thinking the same as you Sunray, but obviously we don't encourage guesswork so didn't suggest it.
I totally agree with your comment and I don't normally offer a 'solution' like this, I would more usually go down the line of offering advice on testing.I am thinking the same as you Sunray, but obviously we don't encourage guesswork so didn't suggest it.
No it isn't. That's fake news.As per the other box shown, maybe it's connected to the back box.
Earthing via the faceplate screws to the box is allowed.
But common sense does apply in the UKBut foreign regs don't apply in the UK.
That is why I always say putting a 13 amp socket on a lighting circuit is bad practice
The use of common sense when using that socket removes any suggestion of bad practice.
But the applied lable will give the game away.You cannot assume your customer, or their family members have common sense, or even that they are aware of the sockets wiring status.
BS7671 does not allow a Class I accessory to be earthed via the screws into the backbox.But foreign regs don't apply in the UK.
Unless it was fitted waaaaa'aay backBS7671 does not allow a Class I accessory to be earthed via the screws into the backbox.
Yes I do because it is a requirement that the cpc be terminated in the terminal on the accessory. I would also promote and endorse the running of a flylead to the backbox as correctly required by ET101 and RECI.
Indeed. That is why I always say putting a 13 amp socket on a lighting circuit is bad practice. That is also why I say UK mains voltage is 240v not some arbitrary lower figure dreamt up by bureaucrats.
It can do where there is no fixed lug.Not fitting one does not contravene BS7671.
Which reg says you can’t have an SO on a lighting circuit?
