Which reg says you can’t have an SO on a lighting circuit?
The nominal voltage is 230V (single phase) and has been since 2003.
The UK voltage is 240v
I was replying to your post saying you do this for all switches and sockets and that this is required in Ireland. BS7671 covers the UK and this blanket requirement does not apply.It can do where there is no fixed lug.
There is no such reg. But common sense and good practice says don't do it.
The UK voltage is 240v and has been since nationalisation. In 2003 some bureaucrats decided to call it 230v but in fact nothing changed.
If you go to a customer and see this socket, do you code it?
If the customer wants a socket, usually in the loft, do you say “I’m sorry BS7671 says I can take a feed from the loft light, but I don’t like that so I’m going to take the feed from a socket in a bedroom or landing and leave you with unnecessary plastering and decorating?”
240V is within the acceptable range in the UK and Europe, but the nominal voltage is 230. Please just stop.
You must be turning work down. Instead of running a bit of t&e from a light and printing a couple of labels (totally regs compliant) you would rip a bedroom apart. I have no words.
I suppose you think cenelec just threw a few numbers in the air and picked 230. In any property in the uk, the voltage will be 216.2 (230 -6%) and 253 (230 +10%). The nominal voltage is 230 which gives the range and is the value used to calculate the load in a single phase circuit. If you use 240 the range changes to 225.6 to 264 and your load calculation is wrong. Please just stop.
that is blindingly obvious.I am not a spark and don't do electrical work for customers
For crying out loud can a mod shut this bloke up before a member of the public reads his nonsense. BS7671 follows cenelec and for another go at imparting real knowledge, we do not pick random values and tolerances. They are prescribed as 230 -6% to +10%. PLEASE STOP.I am not a spark and don't do electrical work for customers.
If you use 240 +5.4% or - 9% the range remains the same and you use the correct figure.
You could also quote a "nominal" of 120v +210% or +180%.
Using 230v is obviously wrong unless it is intended to change the supplied voltage and that has not happened in the 16 years since the bureaucrats decided to lie about the voltage.
Interestingly in most of Europe the voltage has been changed upwards from 220v. Even there it is nearer 240 than 230v. One exception seems to be Budapest which is still 220v.
Why call it something it isn't?
This is why there is a band of voltages that are acceptable with limits above and below a nominal value,
How can it be? That's what it IS - the NOMINAL.That may be so, but the quoted figure for nominal is wrong.
