ive a timer and a thermostat in the cylinder; presuming that the thermostat is normally closed until temp reached, then switches open, and also presuming that the timer is normally open, and closed for the programmed period.. What other component would I need and how to wire it so that:
If the thermostat is closed(cold) and the timer closes, the heating begins, until the thermostat opens (temp reached) deactivating both the hot water and the timer's ability to activate the hot water again until the next programmed period (ie until the timer has cycled to open and closed again?
I'm trying to avoid the water cycling on and off if the timer is closed for a long time, temp is reached soon, the thermostat opens, the cylinder cools, thermostat opens again, hot water activated again....
Is it possible with simple components, or does it need some intelligence in the timer? I did wonder if it could be done with a relay where the relay output is also connected to its energising coil, so once the relay is activated eg by a brief pulse from the timer, it would stay closed (because it's own output keeps it closed) until the thermostat in series opens and kills power to the relay?
