Right, so I was looking for ways of holding it or altering it ya dozy git!You are if you think there could be a way to stop a pipe rotating in a pushfit joint without holding it or altering it.
Because I'd only seen them used with outside taps, and not seen a drain point with that thread. Just never bothered to look for one I guess. In fact I've never seen any drain point done this way, they all seem to just poke through the wall on the end of a copper tube on all the houses I've lived in.Why didn't you just use a through the wall tap assembly pipe which has a flange fitted for securing to the wall?
What I did , and after his visit the drain point was pointing sideways. It made me realise I need to fix this. Didn't want to mention this earlier in case the thread went off on a tangent about how to choose a plumber or this and that, but hey, this is DIYN, why fight the inevitable?Keep Calm and call a plumber!
Just wondered if any Speedfit experts out there knew of a better (quicker, less fiddly) way.
It should have a valve on the inside and the draincock is only to keep the dirt out, so finger tight is all it needs
I thought we were talking about a heating drain off not a outside tap, or do you want to take the floor up every time you wanna drain down
You should have a trap in the floor, you sure as hell don't want a dead leg of water stuck through the wall.
