For yacht master theory for example you are expected to calculate tides for secondary ports where the tide is between Spring and Neap. Here you have to use interpolation to work out the tidal curve based on the difference between the reference port at High water and low water for each of the spring and Neap tides. Its all designed to be done without a calculator.
I used to struggle with that but managed to scrape a pass, never found the need to use it in the real world.
Nobody in their right mind will say, I will arrive at 3:46PM because the height of tide above chart datum (lowest astronomical tide) is exactly 2.45m and I draw 2.3M, so 15cm is plenty for me not to run aground. Good luck with that plan.
I'm no stranger to Running aground. Isn't that why God invented bilge keelers.
