Ideal Boilers
In general, they're all a white box with pipes and wires going in and out.
How they're fitted, how they're set up and what they're connected to is of more import.
And warranty backup of course.
That said, I am soon to be installing my first Vokera shortly and it will be a pinnacle 35.
This is for the DHW performance which everyone wants and the wide modulation which enables such a large KW appliance on a property with low heat loss.
Thanks gas112. Did think about a baxi 630 about a year ago. Will take a look at the platinum..
the platinum with 10 year warranty is the original 830
the duotec compact with 7 year warranty is the original 630 .
Although the new 6/830 mark2 are good boilers the originals are a better boiler
baxi platinium compact 10 year warranty been out about 8 years as the baxi 6/800 very proven reliable boiler around 1200 quid far better boiler than a vogue.
Fitted about 60 of them over the 8 years in one form or another only had to call baxi out twice in all that time.
edit
checked, fitted 72 of them
Better than a Vogue? In what way? You can't even range rate a Baxi, almost no parameters available to set it up for the system it's fitted to
they are are a far more reliable boilerand all brass with no plastic components and hundreds cheaper
