Hi I've got a problem with my icos boiler. It shows a F L messsage which means it has a flame error. Initially when I tried to start it it lt and ran for about a minute with a flame established then seemed to shut down and attempt to restart a couple of times. The restart failed and on subsequent restarts it failed to even ignite. Looking it the book it suggested the flame sensor could be a problem so I bought one (took four days to arrive so boiler was off during that period) and replaced it and also the ignition electrode for good measure. The boiler fired up and carried on normally so I thought I'd cracked it.
24 hours later I had a very cold shower and checking the boiler discovered the FL symbol again. I reset it and it fired up (flame was esablished)... ran for about a minute, slowed down again then re-lit and continued to go for the rest of the evening. Now this morning it won't start at all.
One further peice of info that may or may not help is the CO2 reading when the boiler was running at the flue was about 9.5 % with a temp of about 60 degrees.
How does he know this you ask.... well I'm actually an Oil Fired boiler service engineer so have a Testo Gas Anayliser... but have only ever worked on oil so have no idea abot Gas boilers. Is this a normal CO2 reading for Gas (it would be too low on oil which usually produces about 12%)... sorry can'y give a CO reading as my tester is designed for oil so doesn't measure CO.
I'm not a corgi engineer so I'm not going to touch anything on the GAS side of things but I feel I'm competant enough to plug in an electrode or two in my own house .....anybody got any ideas where to look next or should I gve up now and contact Ideal and cough up the £200 call out charge?
