Although not affecting your current problem you should not do this. The pull cord is for isolation for maintenance and does not need to be turned off between showers.
The switch is not actually required by the regulations so you use it as you want.
There isn't much benefit switching it off every time.
To say it is for a plumber's or electrician's use only is ridiculous.
If that were the case then another one should be fitted to work on the first and then another so that...
