I don't actually know the answer to this, but I don't think it's fifty-fifty.
With Joe's coin, any one toss gives a 50/50 chance of heads or tails. But if you watched someone toss the coin and come up with 100 heads (or tails) then it's doubtful if you would bet on the next toss, you'd be too busy looking for the fakery, as the probability of 101 coin tosses producing the same result is negligible. So prior knowledge changes your perception of probability.
If there were two boxes and one contained £250k and the other £1 then the chance of picking the £250k would be 50/50. But this isn't the case. The other box, for want of a better name, has been chosen from 19. It could have contained £500, or £1000, or 50p, etc. Prior knowledge (i.e. how the amount in the box was determined) alters the probability.
The odds of the DonD contestant picking the £250k box from 20 is 19/1. The odds of the box being one of the others is 1/19. So the odds are very heavily on the £250 being one of the others. Now the others have been whittled down to one, is it still 19/1 that the contestant has the £250k, and 1/19 that it's in the other box?
Monty Hall gave contestants the choice of three boxes (he knew what was in which). He then opened one of the other boxes which was empty, and gave the contestant the choice of switching. The odds were determined (after much academic arguing) 1/3 that the contestant had the right box, and 2/3 that it was Monty's remaining box, so he should switch.
Now on Noel's game, if he knew what was in the boxes and opened all the others except one, the odds should be heavily on swapping. I'm not sure how opening the boxes by guessing alters things. Probably not a lot. I'd swap.
Rgds.
