B
Barsteward
whittle the lot down to two boxes, yours and one out there. The boxes have in them £250,000 and £1.
With only two boxes and known values.
Why all the debate and introduction of alternatives?
In my case, because of that annoying Monty Hall.whittle the lot down to two boxes, yours and one out there. The boxes have in them £250,000 and £1.
But why in Monty Hall's case, or DonD with three boxes, why is it 3/2 to swap? It doesn't matter who opens the 'spare' door, there wouldn't be a swap offerred unless the empty/£1/goat had been shown, so it should be 50/50, shouldn't it?
So the whole of academia, after many years of wrangling, is wrong? It's not only the one website concerned, every website gives the MH choice between two boxes as 1/3 to 2/3, so swap. (In our case we are ignoring any banker offer.)It is 50-50 in Monty Hall as well.
My theory is that the banker's basic rule with just two boxes left is most probably
this entire topic should be devoted to bankers.
an entire 'wunch' of them.![]()
cheers for that one Nige F.![]()
There's a very easy way to convince all the doubters.
Take three upturned cups and a small object that each cup can conceal underneath.
Ask a family member to act the part of Monty Hall, i.e. to hide the object underneath one of the cups (without you seeing), and, after you've made your first choice, to lift a cup that doesn't conceal the object. Then you make your swap decision, and then you see which cup conceals the object.
Do this about thirty times, and see how often the object appears under each cup. Unless one of you cheats, I expect that it will be about 10 times under each one.
If you believe that the probability that we're all debating is 50:50, and if you're right, then the object will be under the cup that you first chose about 15 times, instead of about 10.
If anyone wants to send me video footage of such an experiment, proving that the odds work out to be 50:50, then I will gladly send £100 to the person to do so. This is a genuine offer.
If anyone wants to make me the same offer, then I'll gladly send a video that demonstrates that the odds are in favour of swapping, i.e. 1/3 probability of the object being under the cup I first choose.
I daresay that someone will want to claim that this experiment doesn't fairly or accurately represent the problem being discussed. To that person I make the following offer: construct any practical demonstration, of your own choosing, that shows that the alleged 50:50 odds are correct, and I'll still send you £100.
_____________
PS - this offer is not open to Kes or JohnD. Sorry guys, but that's the price of being both civilised and correct from the very beginning.![]()
Softus said:I daresay that someone will want to claim that this experiment doesn't fairly or accurately represent the problem being discussed. To that person I make the following offer: construct any practical demonstration, of your own choosing, that shows that the alleged 50:50 odds are correct, and I'll still send you £100.
Hmm.jackpot said:Its impossible
