You are in london, I have no idea what is expensive there i'm affraid. Ring a few mobile phones of some small one man bands, big companies will have more overheads and you are not likely to get a persnal approach.
Ring Agile - he`s in London . It`s all relative anyway . what % of a house in London @ say £400k is £75. Long live the Free Market Economy and the Unregulated Plumbing industry
Now i just wrapped a tissue on top of the valve and only the quarter of the tissue is wet and then the valve was dry so im guessing very minor leak from the valve, but it couldnt be the problem for pressure dropping to zero from the recommended level in a day ?
There is your first one. If it is on a new valve the installers will fix it foc.
As said check all the others by wrapping a bit kitchen roll around the pipe.
Apart from that; rip your laminate out anyway. It is shyte
The vaillant ecotec boilers dont have the numbers but im filling it to about 11 o clock.
If you press the minus button the bar pressure will be displayed.
Andy.
I think 11 on the dial is a bit much. Fill to 1 bar.
The instructions will tell you what the other buttons are for.
You should know what they do because when you fill this boiler there is a procedure to follow which will need you to use the menus.
If you don't your boiler will be full of air which is a no no.
Andy.
dont think a minor leak like that could drop the pressure of the whole system to 0 ?
Have you got the instruction book for 'installation and servicing'
Andy.
why havent they made an infrared gun so you can just turn the heating on
