why havent they made an infrared gun so you can just turn the heating on
They have....
Call leakbusters.....
http://www.youtube.com/watch?v=ZdxfnXtwW7U[/QUOTE]
Just rang them but theyre closed until 4th ¬¬
They have....
edit: yes i am doing everything fine except for one bit..it says to loosen the A.A.V valve ? what is that ? and i havent touched it so i hope its stil loose.
2 things - 1 as suggested follow the instructions and also vent the air out rads . 2 worst case scenario with a leak under the laminate floor -remove the rads and seal up the pipework - cut into the flow+ return that goes to underfloor area - plug one and pump up the pipework with a heating pressure test pump Then you will know 100% that the hidden pipework is good/ or leaking. That should take a day with the fiddling about draining etc. including re connecting if it`s ok. So you keep the floor or re pipe above it if that can be done and still keep the floor.
You don't need to know.
Leave it alone. Get yourself a bottle of your favourite swally, chill, and ring the installer on Tuesday.
Has anyone checked the precharge pressure in the expansion vessel in the new boiler? Too high or too low will cause this problem.
Yeah but that was in 1980Mate, beg borrow steal a yellow pages from someone, You cant complain at those call out prices based on the price of your home, a call out here would be between £30 and £50, bear in mind my house cost £72k
