M
mdf290
Bernie said
WRONG I said they still send and dont just go to sleep after the first report. I do not know how many continued reports occur but it is NOT a single one which YOU should remember because I already told you this.
Bernie said
Wrong a Yale 6200 works for up to three years without any external power at all.
Brenie Said
... and some dont..
Bernie said
Some well known household name companies just stick in two pirs when in reality four or more may be needed but their install staff have to fly round hitting targets. Again you are technically wrong about the operation of the Yale pir before it goes to sleep.
Have you actually TESTED one yet B.
Bernie said
What I said had NOTHING to do with alarms being jammed and simply mentioned people IGNORING alarms.
Bernie said
And why therefore is it wrong for me to point out when someone trolls and scaremongers? Why is it not appropriate for me to correct someone when they are wrong?
Bernie said
How can you even say that when you have NEVER even had one fitted or tested in your home.???
Bernie said
You are an idiot Bernard.
You just cannot fathom what I previously explained that these alarms are some peoples ONLY recourse to home security given the budgets these have.
You advocate Monitored systems and not just any but one where the cutting of the phone line has no effect therefore dual signalling.
So what you are actually saying is unless you pay £2000 for an alarm it is not worth buying.
You just cannot stop with your weird fixation and accept that given the budgets and the risks a Yale system is actually a perfectly workable solution and you keep harping on and on and on and on and on.
You have totally ignored the important points I mentioned to suit trying to funnel the conversation down your incredibly boring little back alley.
Give it up Bernard you are on a losing battle Yale sell hundreds of these alarms every week.
Not only that but Yale also do 866mhz systems with rolling codes so you are not even portraying the correct opinion anyway.
People fit these alarms and here's something you obviously haven't realised THEY WORK!
If you dissuade just ONE person from having an alarm installed and they get burgled as a result that will be on YOUR conscience Bernard NOT MINE.
You have said they send a motion detected and then go to sleep until a minute without movement has passed, then they wake up again.
Bernie said
The electricity is off for more than 10 hours
result - alarm will not work
Applies to all alarms
Brenie Said
Cut phone wires ? A good alarm that relies on phone line does not have the line run where it can be cut. A monitored alarm often has the critical line monitored and cutting it will create an alarm at the monitor station.
... and some dont..
Bernie said
Some "professional" installers may not do a full survey, but most do, some who install wireless linked sensors have the necessary test equipment for verifying signal strength and other critical parameters are aceptable. And those the sensors on that quality of system do not send once and then go to sleep but continuously repeat alarm messages until they receive confirmation from the panel that their alarm has been received. Not possible on one way licence exempt channels.
Bernie said
You know the connection between this and the link that prevents the alarm sounding when jamming occurs. The same does NOT apply to wired alarms which cannot be made to false alarm from outside the property simply in order to make the owner turn off the jamming detected alarms.
Bernie said
And you promote DIY alarms because you sell them and then charge for installing them. Hence you have a vested interest in them.
Bernie said
I can say that in my home it is likely that the jamming detection on a Yale alarm would have to be turned off to prevent my neighbours being disturbed by "false" alarms. These alarms would be caused by legal transmissions on the channel from nearby properties found by using an off air monitor ( as a professional installer of radio systems you will know about these ).
Bernie said
The public domain information and freely given information from Yale Technical supports my profession opinion about alarms that use one way communication on licence exempt frequencies.
In an ideal environment they will work but if one wishes to rely on them continuing to work when needed then one has to ensure that ideal enironment is maintained. Because the radio channel is licence exempt there is no recourse if a neighbour starts using the same channel. The only time action could be taken is when a criminal uses a transmitter to block the systems in a street but even then there is the need to prove intent to commit a criminal act.
