Is the bell box connected to the panel by wire or a wireless link ?In the case of a Premium alarm the control panel is within the home and thus meaning the sensors have a better signal path than an external TX.
YESDo you mean you witnessed the problem on site? A simple yes or no will do.
The off air monitor available to an un-trained person during the periods of interference did not have either a directional aerial or a signal strength meter so tracing to a precise location was not feasible.But you were not able to identify where the interference was coming from
Yes, a row of semi detached houses. The link is between an industrial unit and the house of the owner.about an ordinary domestic house in an ordinary residential street? How did this house come to have a telemetry link in it? Mine doesn't.
So an industrial unit (not a domestic house) is involved.Yes, a row of semi detached houses. The link is between an industrial unit and the house of the owner.
The "match" is close in that the telemetry receiver in the house was affected by transmissions from a transmitter in a nearby house. A receiver in a Yale alarm would be affected as well. If the Yale had jamming detect enabled it would have gone into alarm mode when the interefering signal was present. If jamming detect was dis-abled then the owner of the alarm would not have known his or her alarm was being blocked. Any intrusion would not have have triggered an alarm while the alarm was blocked.As you know, a Yale alarm is typically installed in an ordinary domestic house, usually a fairly small one, and is not expected to communicate between two buildings. It seems your example is not a close match.
Any intrusion MAY not have have triggered an alarm IF the alarm was blocked.
Please do not change what I have written when quoting me.Any intrusion MAY not have have triggered an alarm IF the alarm was blocked.
... A receiver in a Yale alarm would be affected as well. If the Yale had jamming detect enabled it would have gone into alarm mode when the interefering signal was present. ....
Others have, I respect their professional judgement.As you have never carried out any tests on Yale alarms,
Not correctWe both know that the probability is vanishingly small.
