Hi All,
My understanding is that the regs require that joints in inaccessible locations (which presumably includes ceiling voids?) should be crimped, and specifically, not made using screw-down terminals.
This seems (to me) to imply that a traditional "junction box" system for wiring lighting circuits (as opposed to "loop-in") is forbidden. Is this right? It seems surprising, especially as places like this forum still talk about junction-box systems. Presumably it also means spurs from ring mains in ceiling voids can't be formed using junction boxes?
This theoretical issue leads on to a practical one for me - as part of joining two rooms I've removed the ceiling and had a steel installed. This has revealed an extensive lighting junction-box system and a ring main with various spurs (and which I've had to cut to get the steel in). Do I need to replace that whole lot?
Thanks a lot,
Adam
Nope. The regs aren't retrospective, and certainly not in this instance.
Your new work, where you have cut cables, does need to be compliant.
