I do not know.Would having a 221 (for an additional conductor) in a J804 render the whole no longer MF?
I would not be surprised if it did, and I could see the sense in such.
As BAS has said, it would not surprise me at all if such an overall assembly ceased to be 'MF'.Would having a 221 (for an additional conductor) in a J804 render the whole no longer MF?
I would say the same as above. I don't think anyone has claimed that the connectors within a J803/4 are, in themselves, 'officially MF'.What about one J803/4 connector in a chockbox?
Isn't this another case of 'type testing', as with CUs? In other words, for the totality of an assembly to count as an 'MF junction box', does not the enclosure have to contain (and only contain) components recommended/approved by the manufacturer - the hope/intention being that such assemblies of enclosure/contents will have been tested by the manufacturer.I know it's hypothetical but the point is that having the MF verification markings on the container is not really related to the connections .
Surely that is the only part that must be MF; i.e. different than a non-MF (screw connector) - as you apparently later contradict this quote and agree.I don't think anyone has claimed that the connectors within a J803/4 are, in themselves, 'officially MF'.
Yes, I agree that the characteristics/performance of connector itself is the crucial bit (just as I think that the characteristics/performances of the devices within a CU are the crucial bit), but there are undoubtedly other requirements for an 'officially MF' junction box (presumably specified in BS 5733) - e.g. regarding cable restraint. Particularly interesting is what Wago say about 'down-rating' the Wago connectors and imposing a limit on the 'aggregate' current within a Wagobox if one wants conformity with BS 5733.Surely that is the only part that must be MF; i.e. different than a non-MF (screw connector) - as you apparently later contradict this quote and agree.
See above. If BS 5733 imposes requirements such as maximum aggregate current, then that might mean that what you suggest would/could be non-conformant - and it is certainly unlikely to be an arrangement that had been 'type tested' by the manufacturer.What about an additional J803/4 connector in a J803/4 box - how can that NOT be equally MF?
You're talking about 'certification' again, and I'd like to hear more about this from someone who actually understands. As I said before, it's surely possible for a product to conform to relevant Standards without any 'formalities', so I wonder what 'certification' you have in mind.Or it might not. Genuinely, fully, certified compliant MF junction boxes are available.
Indeed so - so, again, we need to know what BS 5733 says...That seems similar to the J803 and J804. The number of connector blocks being the only difference.
Quite so - what what were you thinking would be the consequence of adding, say, a fifth connector block to a J804? [if, for example, it resulted in a further 12A reduction, there would not be much 'rating' left ]The J803 has three connector blocks and is rated at 32A,
The J804 has four connector blocks and is rated at 20A.
It could be used on a 6A (lighting) circuit where it is more likely five might be needed.what what were you thinking would be the consequence of adding, say, a fifth connector block to a J804? [if, for example, it resulted in a further 12A reduction, there would not be much 'rating' left ]
True.It could be used on a 6A (lighting) circuit where it is more likely five might be needed.
I do not doubt that they are - but the fact that they are different is interesting - again, quite possibly down to BS 5733.I would think that the 32A and 20A ratings are more nominal, coinciding with MCB ratings, than an absolute tested maximum.
Good point. I hadn't given it much thought.As I've implied, I really don't understand this 'down-rating' and imposition of a maximum 'aggregate' current business at all - whether it is due to BS 5733 or whatever. One might think that it could have something to do with thermal considerations - but if the implication is that the contact resistance of the connectors is such that significant heat in generated in them, then they would surely not be fit for purpose, would they?
Yes, I suppose that it may be related to heat generated in the cables, rather than at the 'joint' (which one would hope would generate minimal heat).Good point. I hadn't given it much thought. I just assumed that it was that four connectors had more conductors - all of which may be at 70° - but, of course that has nothing to do with the current, has it.
Yes, similar story, I suppose ... if one has three conductors in a cable each carrying X amps, then the conductor temperature achieved will presumably be higher than if there were only two conductors each carrying that current - so, t'other way around, for the same max conductor temp, the max permissible current (per conductor) would be lower when there we three conductors, rather than two.Having said that, three phase cables have a lower rating than single phase for the same csa; is that the same?
What I meant was that even 6A conductors could be at 70° - so, limiting the rating of the box does not mean the temperature inside will be lower.That obviously does have 'something to do with current', since the 70° relates (we assume) to the conductor carrying its maximum rated current.
Yes, but if you had a conductor which 'alone' would achieve a temp of 70° with 6A flowing (probably not possible with available cables and regulations), then if there were two or more of those within a confined space, you would have to reduce the current to less than 6A in order to limit the temp to 70° (because of the raised ambient temp).What I meant was that even 6A conductors could be at 70° - so, limiting the rating of the box does not mean the temperature inside will be lower.
Indeed, but the same issue. Yes, it could be that they are trying to limit all conductor temps to 70° - but the more conductors one has in a confined space, the lower the current that can be 'allowed' if the temperature of (all of) the conductors is to be limited to 70°.The 804 can still have more conductors at 70° than the 803.
