Another reason for condensation is the replacement air being cold and cooling the water vapour before it can be removed. If possible the replacement air should come from a warm area.
I imagine it usually will be 'relatively warm air' that's sucked in (from remainder of the house) - but, I would also imagine, rarely as warm as that in a room where a bath or shower has just been had.Another reason for condensation is the replacement air being cold and cooling the water vapour before it can be removed. If possible the replacement air should come from a warm area.
To put it another way, then -I presume that it was simply being said that if one doesn't suck the moist air out of the room quickly enough (replacing it with dry(er) air sucked in), some of the moisture from the moist atr will inevitably condense on surfaces in the room, causing 'damp and mould'. ... so, the faster one sucks out the moist air, the less will/should that happen.I haven't read all the thread but -Is that possible? Also, so what?the airflow just isn't strong enough to pull up the moist air before it circulates and condenses on surfaces.
I guess that (unless it's heated), the floor will qualify as one of the surfaces on which non-extracted moist air will condense, but most will probably be on vertical surfaces, or ceiling.To put it another way, then - If possible, will your feet get wet?
Then the warm air will cause condensation on the cool tiles/surfaces.Another reason for condensation is the replacement air being cold and cooling the water vapour before it can be removed. If possible the replacement air should come from a warm area.
Agreed.I have to say that I often wonder how justified all the fuss about 'damp bathrooms' really is.
Yes. Mine included.Whilst I certainly have seen a few bathrooms with mould problems, I've also seen an awful lot (many without any extractor or other significant ventilation) which don't!
... and mine! Ironically, one of the worst cases of 'mould problems' I've seen is in the bathroom of a family member who has a tiny bathroom with a pretty high powered extractor fan which extracts straight through a wall, with virtually no ducting!Agreed.I have to say that I often wonder how justified all the fuss about 'damp bathrooms' really is.Yes. Mine included.Whilst I certainly have seen a few bathrooms with mould problems, I've also seen an awful lot (many without any extractor or other significant ventilation) which don't!
If it doesn't result in mould or rot, then I'm not sure that I understand what is the problem with condensation, per se, in what is essentially a 'wet room'!The fact that mould may or may not result is neither here nor there for me. What is the end goal is limiting the condensation build up in this room in the first place.
I classify a room with water and steam as being a 'wet room', and it neither surprises nor worries me to see condensation in it, if it's doing no harm (e.g. mould/rot) ... but I guess it's a personal thing!Simply clearing the condensation. And, NO its' not essentially a wet room
Yes, I know all that. That's why I put 'wet room' in quotes!If you type in wet room in google you will get the proper idea of what a wet room looks like. The traditional bathroom and modern 'wet room' are miles apart afaic.
Kind Regards, John
