I had assumed the writer had just extracted the lines from the report where he thought something is wrong, i.e. all the C1, 2, & 3s.Do people normally write reports like that - it sounds like the work of a mindless robot?
... but, as I said, in large part it is not a "summary of faults" - for many (most) of the items it is just a statement of a regulation, without any clear indication of what the alleged fault actually was.yes it was just the summary of faults, several of which appear to be labelling issues.
Exactly, as I said, 14-17 are clear (even though 17 may, as you say, well be 'wrong') - but items 1-13 are not clear (although one can guess, although one shouldn;t have to, about the labels.1 - 5 Requires a sticky label.
6 - 12 Can't actually tell what is wrong. Only the test headings are shown.
13 - Requires another sticky label.
14 - Is correct. Shower too big or MCB too small.
15 - Self explanatory.
16 - Could be correct depending on the reason for the RCD
17 - Wrong if just because it is old.
Yes, probably - although the problem with the shower circuit might be another, as could be the 'missing fuse carrier' (depending on what that actually means).Thank you all for your help. Would the 100mA RCD issue be the main actual safety issue as far as one can tell from what I have posted?
OK for that purpose, but ...If it was installed because you have a TT supply (earth rod in the ground), no it is ok.Would the 100mA RCD issue be the main actual safety issue as far as one can tell from what I have posted?
... could it not be argued that the absence of 30mA RCD 'personal protection' for shower and sockets etc. (particularly any sockets which might be used to power outdoor tools) was a 'safety issue'?If it was installed for personal protection, yes.
Yes, we understand that. Items 14-16 (the only ones {plus 17} for which they've typed, rather than 'pointed and clicked!) probably deserve attention - and it might just be that 17 (replacing the CU) is the simplest/easiest/cheapest way of addressing the RCD issue and maybe other issues.The quote for the works that the letting agent acquired did of course cover everything on the report (at over 2 grand) which is why I am trying to understand what I actually need to fix (while trying to be fair to my tenants)
Yes, that's what I wrote.... could it not be argued that the absence of 30mA RCD 'personal protection' for shower and sockets etc. (particularly any sockets which might be used to power outdoor tools) was a 'safety issue'?If it was installed for personal protection, yes.
If it was installed for personal protection, yes.Would the 100mA RCD issue be the main actual safety issue...?
Sort-of, but I wanted to be sure that the OP fully understood, since there appeared to be a certain amount of ambiguity, with the talk of 'what it was installed for'.Yes, that's what I wrote.... could it not be argued that the absence of 30mA RCD 'personal protection' for shower and sockets etc. (particularly any sockets which might be used to power outdoor tools) was a 'safety issue'?If it was installed for personal protection, yes.
