As I said previously, if there's a 1" connection on the cooker that suggests you'll need 28mm into it, not 22mm as 22mm might well be too small. If there's currently only 22mm in the kitchen, a new supply will need to be fitted, possibly all the way back to the meter if it's only 22mm at the meter.
It'll also need an interlock fitting so the gas can't be turned on unless the extractor fan is on.
There isn't a lot of technical gas stuff freely available online. You need to buy yourself some books
The valve on the cooker is 1", so a 1" male fitting would screw into the valve, but on the other side, I guess it has to be 22mm male so that the 22mm copper would be screwed into it it with a compression type fitting.
So far I find this:
http://www.leagrave.net/product/30062/endfeed_male_adaptor_22mm_to_1_
but I think the one I need is male to male, so that the 1" male goes into the valve and the 22mm copper is screwed with a compression fitting to the other side rather than solder. I am thinking in case the cooker has to me moved or disconnected? Because with this fitting you still need to use another screw on/ compression type fitting in order to move the cooker if you have to.
IF IT'S 1" ON THE VALVE, IT NEEDS TO BE 28MM INTO IT, NOT 22MM. YOU NEED TO UPGRADE THE 22MM TO 28MM FROM THE GAS METER. I'VE SAID THIS THREE TIMES NOW!!!
Seriously, if you can't listen to basic information like this and take note of it after three attempts, you're not going to get very far in your career
