S
Shutpa
drewroof said:hi there, reconnect it, then go to printer/properties,then click on update driver then just follow the wizard
I'd still like to try drewroof's 'printer/properties. Would this be in 'All Programmes'?
JohnD said:it looks like a printer cable!
pretty well obsolete now
you can get one with a printer plug on one end and a USB on the other.j
Found printer/properties at last, but no sign of update driver.drewroof said:hi there, reconnect it, then go to printer/properties,then click on update driver then just follow the wizard
JohnD said:Hee hee!
p.s. during the re-install, it might ask you if you know where the driver is, so you can navigate to that address you mentioned earlier. It wil usually automatically find the best one.
bolo said:I was given the code 'C:\Drivers\printer\X1100' to type in at the end.
Spark123 said:If you go to the start button, select control panel and printers/faxes you should get a screen up with the icon for your printer. If you right click it and select properties, ports tab, is USB ticked?
