That'll use twice as much as fixing it to the underside, clamping it between a screwed batten and the joistPlan is to lay it over the joists and creating pockets between each joist.
That stuff that stops debris/people falling off scaffold. Can be free too if you can find some scaffolders taking down and wazzing large amounts of it in a skipIf netting is best, what would you recommend?
Oof, that's a bit skinny. If that's how deep the joists are I'd use PIR between and overAssume 100mm is plenty?
Hmm.. depends on the quality of fit and future shrinkage. Wool self expands to fill gaps and is a lot faster to fit well than PIR, to the extent that if a bad PIR install ends up with a draught blowing round the boards, it can become useless and the wool, though it's only hlf-to-two-thirds as performant thermally, does a better jobPIR is vastly superior
10%+ heat loss through a floor isn't what I'd call "little", but I get what you're saying - if there was a certain amount of cash in the for-insulation pot I would spend it on the floor lastIn my opinion floors are the last thing to insulate in a house because you get so little gain.
Heating the room is what makes a difference to the warmth of the room. The insulation just means it leaks away at a lower rate. If it's cold on that thermostat setting before, it'll be just as cold after, but the boiler will fire up less and the gas bill will be lower. If you want the floor to feel warmer, make it the heat emitter for the room; insulate it and put UFH inthe insulation has made zero difference to the warmth of the room
Not a breather membrane; a vapour control (impermeable) membrane. You want the breathable bit to be on the world side and the impervious bit to be on the room sidethen a breather membrane on the joists
It works both ways; heat stored in a large sink evens out temperature swings in the house when the temperature falls and the warmed block of concrete starts emitting it insteadWouldn't the concrete just act as a massive heat sink and take ages to get warm?
Draughts are one of the most effective things at making a human feel cold even if the ambient temperature is acceptable. As well as carrying away your paid-for heat and cooling building materials theyre exposed to, if your skin is exposed to a draught it strips away the layer of warmed air around your skin, making you feel colder than you otherwise would; google "windchill"It is not the draught that makes it cold but the heat loss because rockwool is **** and thermal bridging
I've got concrete here, with 50mm of celotex on top and 22mm chipboard on top. It's a floating floor, no joists, just held up by foam and held down by gravity. The celotex makes a vast difference in comparison to the other rooms that are just concrete. No numb toes, and the room stays warmer for longer.
I frequently deal with boxes of stock for my business, which are stapled. I find that in just a few years in a dry environment the staples turn brown and crusty. Under a floor, relying on standard staples could be risky. Eventually the whole lot will fall off the underside of the joists.
Thanks Robin. Really appreciate the detailed response.That'll use twice as much as fixing it to the underside, clamping it between a screwed batten and the joist
Rockwool isn't ****; it has a lambda value between 0.032 and 0.044 on PIR's ~0.022 meaning it flows between 1.5 and 2 times as much heat as PIR does, but rockwool is a better gap filler around irregular or solid objects and when installed under slight compression will always try to expand and keep gaps closed. PIR is rigid and predominantly incompressible and needs careful foaming in. It is also known to shrink over time, which means that your well fitted PIR now may one day be letting draughts in. On a cost basis you can usually buy enough of either wool or PIR for a given amount of money that you can achieve the same insulated result if you have the space for the thicker amount of wool required
Overall the difference between PIR and wool isn't as stark as you think, especially when you consider that wool will generally do better to provide ongoing draught resistance in awkward spots. While it's commendable that the building regulations have been tightening/improving insulation requirements for a number of years, they have long remained particularly awful with regards to draughts/air tightness. When one looks at passivhaus systems, where no space heating system is required at all, the spec that they're built to with regards to insulation is about the same as what the regs now demand, but the draughtproofing that passivhaus requires has long been around 10 to 15 times better than the regs.
All the insulation in the world can't solve the problem of cold air blowing through a gap in it, and cold air permeation needs to be kept on the world side of insulation, rather than allowed through to the room side/the back side of the plasterboard.
Good to know. I wonder how many actually use them?Tacwise do staples in stainless but even the normal ones are galvanized
