Insulation advice
My amateur response would be - why not just fix insulation underneath the passageway boards? (as aveatry is suggesting), maybe insulated plasterboard?
I'd also insulate under the floor from above
Not sure if plasterboard will be happy outside. If access is easy from above then you could do both I suppose
I'm just unsure of the best option and dont want to do anything which could make things worse.
The passage way is split 50/50, next doors front bedroom overhangs the entire front half and our rear bedroom overhangs the entire back half.
I do have access from above if I pull up the boards and was planning on ripping up the carpets anyway.
I guess if I can avoid disturbing those potentially harmful boards then that would be the preferred option although a bit more fiddly.
Obviously I want to try and get rid of the cold/damp without going nuts too and going over the top.
I would discuss it with your neighbour, and maybe make it a combined job for the outside part at least. You will both benefit.
