What do you mean by a "0 reading"? If you mean "0 Ω", then that would be a 'pass' in a 'continuity' test - but I presume you are talking about a 'fail' (broken/disconnected conductor), aren't you?If there is a 0 reading for a continuity test ...
Plausible, yes - but, as I said, not necessarily the best, or necessarily even the most sensible, approach.and there is no obvious visual clues, when would the ring halving method not be a plausible approach to proceed?
I'm not sure that is really necessary. If you have properly identified the nature and location of the fault, there's probably no need to prove it further by 'bypassing the fault.Also, once you have tracked down the fault and subsequently proved with a temporary cable that the tests are now successful...
Provided you are certain that the only fault is in the one segment you've taken out of service, then I can see no problem with that approach Indeed, a good few people would probably have preferred it as two radials (rather than a ring) in the first place!, is there any issues with the 2 radial approach, if replacing the cable is deemed impractical?
That understanding (of whether there were any 'obvious flaws) would also result from having "an expert understanding of electrical concepts'.I’m sure an expert understanding of electrical concepts will provide one with more options but I’m trying to understand if there are any obvious flaws with my suggested approach.
Kind Regards, John
