Then I would guess limescale.
Just so I understand - when there is a limescale problem - should I not see reduced pressure?
No, it will need proper diagnosis and treatment.
It was installed by Intergas certified and GAS safe (CORGI??) registered engineer - just wasn't serviced on annual basis. Installed in 2010 so roughly 5y old.Lime scale is not a problem PROVIDING that the boiler is operated at the correct settings.
That would normally be done by the competent installing engineer and then rechecked by the engineer at the annual service!
I can never understand why some people get boilers fitted by unregistered builders and then never have them properly serviced every year.
Tony
If the installer was Intergas registered then it would have had a five year warrantee!
But to validate the warrantee the boiler needs to be serviced every year!
If he was Intergas registered then we are likely to know him. Also we might know where he has "disappeared" to.
Tony
Being gas safe and IG registered name little I'm afraid.
Postcode searches also don't necessarily mean finding the right person for the job.
I'd say dan Robinson would be a good man for the job
Chocca until the 10th though - assuming that Gas service isn't laid.
Need to make up that flushing rig too.
Decsales on these can run anything from £250 - £350+VAT depending on how bad they are.
Wise to double check its needed first though.
OK - but not in the office until Monday PM. Mobile number is on the website (in my profile) if you want to ring Monday morning.
