Were is the info saying 95.8%?
I've posted it above, have you worn google out for the day??
Murphy's law applies to every boiler if all safety devices fail at the same time... The Titanic was never designed to be unsinkable, it was only claimed to be unsinkable.The Titanic was not supposed to sink. Are you familiar with Murphy's Law?
Is that comfirmation that the flow sensor is pulsing type of sensor.Not sure how a Hall effect sensor could fail in such a way that it continues to send pulses, they don't have epileptic fits as far as I'm aware??
Not verified as accurate.Then there is a paddle flow switch which we already know has a habit of sticking and most manufacturers stopped using 10yrs+ ago,
Fail to on numbnuts. I said, fail to on.If the sensor cannot fail then why do Intergas make spares available
So are you confirming that the output is pulsed and the control system requires pulses to determine "flow" and recognises either static state as "no flow"It's a turbine with a Hall effect sensor.
If there was a false indication of flow and the boiler fired up then when the thermal mass was heated without cooling water flowing through it the over heat sensor would eventually operate and shut the boiler down.but there are no reports of it ever leading to a situation where it became unsafe.
Razor900 has explained how the flow detection system ( sensor and pulse counting logic in the control system ) may be fail safe.Fail to on numbnuts. I said, fail to on.
I wonder how efficient the one with the built in recovery unit is - or perhaps I already know
There are Hall effect devices that give a steady ON state when the magnetic field is varying as would be produced by a turbine
What or where is Appledore razor?
The stock answer when encountering people with superior knowledge and education.I've posted it above, have you worn google out for the day??
Here its is:Or you could just buy the new water heater that Intergas are not far off launching
