- Joined
- 25 Aug 2008
- Messages
- 5,776
- Reaction score
- 2,941
- Country
They don’t hence the reason I was there to fix themso back to a variety of back end rot, only in a modern boiler
So when that occurs how do the flue gases pass though the boiler ?
It will attempt to fire but due to back pressure the air gas mixture can’t push through Venturi into burner so won’t light.What happens when the boiler is commanded to fire up but the flue gas route is obstructed ? Does the boiler fire up and choke or can it detect the flue route is obstructed and thus not make any attempt to fire up.
This is due to boiler not been cleaned properly every year.
I'm at home all morning![]()
Got between a quarter and third of a 5 litre drum. Been in the store several years, have no idea whether it loses potency. Doesn't smell as I remember but there is an acrid smell.
I assure you my friend, I am no Mr Fixit.You do not understand, this post and others confirm it. Efficiency is heat out to the potential of fuel in. I'm going to take your advice and stop feeding the troll.
What, now I'm a delivery service? If I go over it'll be late afternoon after Letchworth.
Four houses were converted to un-vented DHW and sealed heating with pumps and valves gear external to the boiler.
Four houses were converted to combination boilers.
Fourteen houses retained the vented DHW and vented heating system
