^^^ Ta for the above.
Trouble is it gives me cause to ask more questions but worries me that I could easily not understand the answers
Bear in mind the present controls are the 24 year old Siemens RWB9 heating & hot water programmer - plus the Honeywell CM901 programmable therostat sited on the hall wall.
On the Siemens programmer the heating side is set to 'permanently ON' with the heating on & off times and temperatures controlled by the, conveniently wall mounted, battery powered Honeywell CM901 - which is hard wired ... (I think it's 240volt?)
The hot water 'on & off' times are set via the Siemens programmer.
If I go down the Honeywell T6r-HW I must ask if it does away with both of my current items? And, given it's wireless, I would further ask if there's a hard wired equivalent instead whereby it could simply occupy the space on the wall currently taken by the CM901 and use the same cable as is already there. When I say it's currently hard wired I mean it's cabled from its position on the hall wall back to the airing cupboard, where the Siemens programmer is (and where the HW cylinder is too).
I stress, I really don't want too much complication - if I dropped dead my wife wouldn't thank me if she suddenly found she was in charge of apparatus more difficult to understand than the current set up.
Having said that, I do accept that at present the boiler cycles on and off many, many times a day, shutting the boiler completely off and firing it back up again ... whereas I gather something like Opentherm reduces this situation, and I don't know if the new boiler would do the same if I retained the existing controls.
(I did say I wasn't very familiar with Opentherm, didn't I ?
