Very pertinent points raised above that I readily admit had no knowledge of.
I've seen references to leaking sumps and pinholes on Ideal Logics (and, obviously the Logic with the option of a long warranty was/is an alternative), and I've seen mention of Worcester using loads more plastic than they used to, Viessman have got this or that problem etc etc ..... the list of issues, pros and cons goes on for each and every boiler. But this forum is helpful in highlighting the aspects to be taken into account.
Yes, re. Opentherm, Baxi said the heat only has no facility for Opentherm so stick with a straightforward two channel programmer .... I don't think that, in itself, troubles me. It's one less thing to complicate life at the moment.
I'm grateful for seeing this reference to the heat only Baxi - it helps to be made aware.
I'm now working on the assumption that the earlier reference to there being a new 800 heat only boiler which is a different and much better boiler to the 600 heat only boiler was wrong and maybe it was the SYSTEM 800 that was being thought of??? (but I stand to be corrected)
Thanks for replies.
Thanks for replies.
