- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,011
- Country
That's simply not true, there was a new gas boiler installed in the basement for the tower, and the existing old gas boilers were kept for the finger blocks outside the tower.They also originally stipulated some sort of community heating system, but this was later changed to gas boilers in individual flats
What was installed in the individual flats were heat interface units which took metered heat from the main circuit and put it into the flats radiator circuit.
The individual flats had their own gas supply from when the block was built, that was used for cooking.
Actually the gap was needed as it was a ventilated rain screen nothing to do with the windows, the problem with the cladding was actually determined to be the aluminium/pe cladding which melted and dripped down while burning, therefore setting light to the rest of the cladding. As you mention there were also no functional fire breaks into and throughout the void, the ones that were installed were not suitable for the location, and many were missing or incorrectly installed.crucially, the fact that there was a gap between the insulation and the original fabric of the building high I believe was related to the way the new windows had been installed. Essentially the gap (which had inadequate fire breaks)acted like a chimney, allowing the fire to spread very quickly up the outside of the building.I believe the window frames melted due to the intense heat.
I recommend anyone interested read the executive summary of the first stage report, as there is so much misinformation and speculation going around, and the report is more accurate and has basis in the evidence painstakingly gathered so far.
