- Joined
- 15 Jan 2019
- Messages
- 8
- Reaction score
- 1
- Country
yep that's me.
Yip,,that is about it!Seriously, General Discussion is a bit of a cesspit.
If you want to stick to fora where you have expertise then that will be fine, and you will be welcome.
If you choose to engage in the General Discussion forum then you will be as welcome there as anybody else, i.e. a "full and frank" exposition of your views and your opposition to views with which you do not agree.
If you want to join in here then your best bet is a thick skin and a firm belief in your own opinions and standards. Personally I would say that here you give as good, or better, than you get, and you don't go whingeing to the Mods. If that's not for you then confine yourself to the specialist fora where you have expertise.
The current entry from the Oxford Dictionary says: The plural of forum is usually spelled forums; the plural fora (as in the original Latin) is chiefly used when talking about a public square in an ancient Roman city.If you want to stick to fora where you have expertise then that will be fine, and you will be welcome
Don’t worry Sheds,I will keep you right,when you are trying to be too smart and your brain cannot keep up with your typing.The current entry from the Oxford Dictionary says: The plural of forum is usually spelled forums; the plural fora (as in the original Latin) is chiefly used when talking about a public square in an ancient Roman city.
That could easily be because of usage, and not because of grammatical correctness.The current entry from the Oxford Dictionary says: The plural of forum is usually spelled forums
Bully.and stop coming back.
It's OK noseall - I'm a big boy - I can stand up to the likes of Sammy in my sleep.Bully.
And of course,,you are talking of ancient roman squares,not 21st century chatrooms.That could easily be because of usage, and not because of grammatical correctness.
Sleepwalker,no surprise there then,,multi talented after all.It's OK noseall - I'm a big boy - I can stand up to the likes of Sammy in my sleep.
Are you and Sir Gal the same person..You both have same "talent" for word salad nonsense.That could easily be because of usage, and not because of grammatical correctness.
No.And of course,,you are talking of ancient roman squares,not 21st century chatrooms.
Your nonsense,,,correct.No.
But I doubt you could ever understand.
