So, no need for blanks on spare ways, then.
That's certainly what you should have been 'asking', but what you actually wrote (as so many people do, so you're certainly not alone) was "...Unless they are claiming you need an IP rated CU" ... which surely implies that "an IP-rated CU" actually has some useful meaning, doesn't it?I understand where you are coming from but I'm asking "what" the IP rating is required to be, not "IF" it has one.
Well...you cant open the door on that one without the use of a tool.....So, no need for blanks on spare ways, then.
There are certainly some dodgy products out there, but I seriously doubt that you would find a CU which (when appropriately populated by devices and/or blank plates, and with the installer not having managed cable entries incorrectly) did not comply with regs regarding IP rating.Assuming purchased from a reputable source. I have had a look on eBay and there are definitely some shady ones on there at ridiculously cheap prices. I doubt they are compliant with many regs.
Agreed. Even the term "weatherproof" is probably better than "IP Rated", although most of us would understand the intended meaning.It may seem a bit pedantic, but it makes me shiver a bit, and makes me wonder whether some might get confused as a result, when I see people talking about "IP rated" items ...
... every electrical item under the sun has (or could be given) an IP rating (hence is "IP rated"), even if that rating is IP00 (no protection against anything). When (like it your post) people talk about "IP-rated items", what they obviously mean is 'having an IP rating at least as high as some (unstated)level" - but some people might not understand that, and might think that an item with any IP rating (no matter how 'loiw' a rating) is suitable for their purpose.
Kind Regards, John
True, but even "weatherproof" is potential misleading, "weather-resistant", or something like that, being closer to the truth!Agreed. Even the term "weatherproof" is probably better than "IP Rated", ...
Again, agreed, in terms of "most of us". However, as I wrote, someone who did not understand and read, or was told, that an "IP-rated" product was needed might be excused for believing that one with any IP rating (theoretically all the way down to IP00 !) would be satisfactory.... although most of us would understand the intended meaning.
Oh yes I completely agree that it's misleading, but probably is more understandable than merely "IP Rated".True, but even "weatherproof" is potential misleading, "weather-resistant", or something like that, being closer to the truth!
Agreed.Oh yes I completely agree that it's misleading, but probably is more understandable than merely "IP Rated".
IP1X surely would not prevent even large fingers touching things would it? ... unless you have fingers larger than 50 mm in diameterI saw a hand drier today with IPX1 rating today, very very basic but it is 'IP rated'. ... Personally I think I'd prefer to see IP1X or even better IP3X to prevent tiny fingers reaching the heater element or impeller.
