I never suggested that it was 'compliant' - I said 'sensible (if, that is, one believes in the value of RCD protection in the situation the OP described).Wrong...RCD plug does not comply....
.. and as I said, I think that is debatable. If he changed the MCB to one of a different rating, then I think that most people would say that that change to the circuit was enough to invoke the need for the whole circuit to comply with current regs. However, I am personally far less convinced that merely replacing a faulty MCB with one of the same rating invokes such a requirement for the circuit.... as i said as soon as he replaces that mcb the whole circuit needs rcd protection.He needs to replace it with a RCBO ...
Do I take it that you would similarly feel that replacing a faulty B6 in a non-RCD-protected lighting circuit would invoke the requirement for RCD protection to be added? If so, I would be interested to hear what others think about that.
What do you mean by "do an EIC" - do you mean 'undertake tests'?... and then do an EIC on that circuit
Kind Regards, John
