I connected up my towbar electrics yesterday via a bypass relay.
My battery was dead after I finished fitting it, but I wasn't sure if that was because I had my lights on and off testing them at the plug to figure out which wire did what.
When I put my multimeter across the inline fuse on the cable that is powering the relay (which is connected directly to the battery) it will give a reading of 12v or more even with the car off and not in use.
When I switch the multimeter to amps DC and put it across it reads 0.
I am just a bit confused as to wether it is drawing any power or not, with a Volt reading of 12.6 but an amp reading of 0.
Cheers.
Cheers.
