Is PTFE safe on a cooker?
I will disagree with you there steel purely from amount of leaks i attended when working for board few years down the line plenty of tape used but was pishing out and fittings were loose
Fitting loose then a parallel thread was used which required a fibre washer or shoulder.
I don't recall two types of PTFE years ago 112??...over the last 20 odd years the PTFE has got thinner and thinner so they decided to manufacture a thicker tape for gas....fook me it's the same thickness we used 30 odd years ago on gas and water..;)
Do you remember using two types of PTFE tape years ago?..cos I don't..
Gas tape is a one wrap jobbie , normal tape then wrap a good few turns...;)
I use locktite now but used PTFE for years..
Only saying what i found steel and it wasnt parallel threads , same as some people used ptfe then coated it with paste , fek knows why but Watson house sent a bullitine out around 30 years ago saying all 3 reacted with each other causing tape to disintegrate
Yep , we had to rip out a load of steel gas pipe in a factory due to paste and PTFE being used.
Back in the late 70's PTFE tape was as thick as the gas tape we have today..
I agree, even in my short career PTFE has gone to being as thin as politicians credibility. Always called gas tape One Wrap too, but never trusted it with a single wrapping.
Loctite 55 was a revelation when I found it.
Steel i remember as an apprentice doing industrial meters and two inch pipe in the workshop . Tested up and it was pishing out . thought how the fek i cant tighten it any more then i smelt it one of mates had mixed my paste with barrier cream . They were all pishing themselves laughin at me getting bubbles at every joint
You would'nt have have missed the barrier cream...............................
