Not just to agree with the client, combi often pushed because it suits the installer.I have to agree too that some installers will happily support a clients opinion and bang in a combi
And it might suit the customer. Proper design is the key, not prejudging the best solution.It suits the installer for a whole raft of reasons...
That's right, but it's often the installers who do the prejudging.And it might suit the customer. Proper design is the key, not prejudging the best solution.
Well, perhaps. "Far too much" is subjective.Correct, and once the open vented is gone, it will cost far too much to put it back in.
Quite, I've occasionally listened to radio discussions about energy saving, and the "experts" talk as if combi is the only type of boiler available. After I've finished shouting at it, I switch it off.Installing a combi, has become the modern, default solution.
So far no one has actually explained what the reason for no combi boiler is
Quite. It isn't the end of the world. Sometimes a combi comes out on top, sometimes it doesn't.It seems to me gospel that a large house needs a system boiler just in case two people use the bath at the same time and the kitchen sink is switched on - Even under those circumstances a bit of low pressure is not dramatic
That does make me laugh. Some of the back ups proposed, such as an electric shower, just in case, are plainly nonsense.And dont get me started on the excuse that at Christmas your boiler might pack up - Thats not an item that factors into it
So far no one has actually explained what the reason for no combi boiler is - It seems to me gospel that a large house needs a system boiler just in case two people use the bath at the same time and the kitchen sink is switched on - Even under those circumstances a bit of low pressure is not dramatic
All considerations and part of the system design process.Boilers have a limited range of modulation, therefore a larger Kw boiler, only providing heating to the house, even on it's minimum modulation, will still be generating too much heat, so they begin short cycling, which is not good for economy, nor for wear and tear on the system.
