Is this a standard price?
26 Jul 2013
Surrey
Hi, I had a combi boiler installed last year and apologies for my ignorance but my last place ran on electric so I have no idea about anything concerning gas.
The guys who installed it emailed me with a quote of £90 incl. vat for a service as apparently you have to have an annual service to be valid for the manufacturers warranty.
Is this price a good price for a service?[/list]
Most manufacturers will require a service to keep warranty valid. And that seems like a pretty normal price yes.
only you can decide that jan
its not a bad price but i suppose it depends on whats done
what do your neighbours pay for their services?
Depends on the boiler and what is required for the service.
Pricing over the internet is usually a pointless affair, but boiler servicing is a little easier to predict - so... We charge £84 incl VAT, but not any spares or remedial works.
You DEFINITELY need it to be done properly by someone for the warranty to remain.
That's reassuring to know. If the boiler is only a year old and everything seems to be running as it should, it should only cost me the £90 I'm hoping, or are there bits and pieces bolted on to the price typically?
I suspect that by taking the trouble to post on a forum, the OP is in shock and probably expected it for under a tenner.
Not normaly anything extra, if any faults are found then the manufacturers would be called to repair, or if its with the installation of the boiler then the fitter (who is servicing it) should sort it out.
1st years service wont normaly involve anything too intensive (depending on boiler make)
Ha ha, not at all. That would be wishful thinking. I wanted to make sure someone wasn't having a chuckle at my expense. Would you buy something without knowing its approximate market value?
What market value? You're buying a service not a commodity or finished product. Some wh*res charge a few quid, others thousands for the same service.
It's irrelevant whether it's a service or commodity. Fact is if you're paying for something you need a guideline on what is acceptable for what you're getting. I've had some very helpful answers and my question has now been answered but thank you for your input.
It is relevant. Are you going to research the thoroughness of what you've had done, like you've done for the price? Your service might be worth twice what you've paid or then again not worth half.
Hence why your post is pointless in it's simplicity.
