OK - "thick as your arm" was a bit of an exaggeration. But not much - FWL's sizes above of 400mm2 and 780mm2 equate to diameters of (only ) 22.5mm and 31.5mm, so with insulation say 25-35mm? So a flat-twin cable would have a major axis of 52-72mm? How wide is your wrist? Mine's about 70mm...security1 said:Err - sorry to be a bit thick and that, but I have just come home in my motor car. Seems to run by something called electricity at 12v - whatever that is I do not know I am sure.
Let me see now - just gone out to look at the cable sizes - can't see any as thick as your arm. Total fuses 30. Total rated amps 505.
Now, we couldn't. People would not want wiring looms in their houses, and also don't forget that as our houses are not made of metal which provides a handy common return path for everything, we'd need twice as many cables as the car.Ah, I get it - it has a wiring loom and of course the car itself is neg earth- whatever that is.
Of course we could not possibly use that system in a house - goodness no.
Also theres the little matter of voltage drop to consider, since most people's houses are a fair bit bigger than even a large car.
I don't know if you've ever tried to introduce a new electrical item, or circuit into a car - it isn't easy, and not just because it's cramped. I don't think many people would thank you for introducing the same level of difficulty to their homes.
Your car has 30 fuses. Count the numbers of lights and other electrical items on board and then do the same for your house.
Your fuse values add up to 505A at 12V. This is equivalent to less than a single domestic ring main.
There's nothing wrong with lateral thinking, but any idea that you come up with, by whatever means, has to work if you want to put it into practice. And hundreds of circuits in a house supplying individual lights etc is not a workable idea. A shower cable as thick as my wrist is not a workable idea. If pointing these things out makes me a plonker in your eyes so be it.We all need self satisfied plonkers who can only think in one direction - backward and are more interested in trying to prove something wrong than a bit of lateral thinking.
